nickysteveo avatar image
nickysteveo asked
Phoenix Inverter 12/3000 fan remains on
Hi
I have had this inverter for a few years now.
Usually when I use my inverter to power my 240 circuit from my batteries the fan would only come on if I was running a heavy load item like the toaster. The inverter box would feel warm so I think it was coming on correctly.
But recently I have found that my fan comes on a few minutes after turning the inverter on and remains on. There is no heavy load item being used and the inverter box feels cold. So I do not know why this is happening.
Has anyone else had the same experience can anyone suggest any remedies?
Maybe the fan/thermostate needs cleaning or replacing, does anyone know how easy that is to do?
thanks
Nick
Phoenix Inverter
wkirby avatar image
wkirby answered ·
It is possible that over time the inverter has ingested dirt carried in the air.
If this has happened, then dirt has deposited on the heatsinks thus reducing their cooling effectiveness. Passive cooling is now not effective enough even with light loads, so the fan comes on to compensate.
nickysteveo avatar image nickysteveo commented ·
Hi thanks for the answer, could.you tell me how I can ascertain that that is the problem and if so rectify it?
Thanks
Nick
