eikone avatar image
eikone asked
Buck boost settings wrong?
I have setup the following system:
Victron Buck boost connected to car and lifepo4 Victron smart lithium 100ah.
Smart shunt and bmw712 installed..
Ve.bus BMS installed
Here’s the problem. When I connect via app to the battery, my lithium battery has 13.5 V already.
With ts config I have set a full battery voltage of 13.2V, charging Voltage of 14.2 with 40A. Unfortunately the buck boost switches on and keeps charging. I am afraid I will damage my battery.
The green wire is connected to the vE.Bus BMS at charge disconnect pin.
What did I do wrong?
I have enabled the bms in ts.config. Since then the checkbox for the green wire is greyed out. Should I disable this and check the green wire checkbox instead manually??
Please help
battery chargingBMV Battery MonitorBMS
