BlueTrepidation avatar image
BlueTrepidation asked
PV Inverter Always Shows 0 Watts on Dashboard
Hello. Attached inverter is a ABB UNO-DM-5.0-TL-PLUS-US on the AC output of two MultiPlus 24/3000/70-50 120V in a split phase configuration. The ABB inverter is communicating via sunspec protocal to Venus OS v2.93. AC totals shows the correct output power but the dashboard always shows zero. Is there a way to fix this? It's been several years and I can't find a solution. Thanks.
MultiPlus Quattro Inverter ChargerVenus OSgrid
mvas avatar image
mvas answered ·
Your text implies ... USA 240 Volt split phase ?
But the first image shows 3 Phase?
BlueTrepidation answered ·
Yes. This is a single phase 240 volt system. The 1st image is how my inverter shows up once it is added to the system. Can I manually change this or is there a bug where a single phase inverter is showing up as 3 phase?
