banne avatar image
banne asked
SOC percentage scheduled charging
Why is it not possible to charge per 1 percent with scheduled charging? It go's in steps of 5% which causes some overvoltage issues with my BMS when it charges to 100%. 95% is a bit low, I would prefer to have the possibility to charge it to 99% if I want it to. Seems like a very simple change in the setting to apply
Multiplus-IIbattery chargingSOC
You can voltage cap in DVCC. That usually sorts that out.
banne avatar image banne Alexandra ♦ commented ·
When cells are unbalanced at 100% thats not really a solution because 7 cells undervoltage and 8 cells overvoltage are still together 51,4v
Alexandra avatar image Alexandra ♦ banne commented ·
Longer absorption helps there. And your battery balancing system should sort it out.
The main issue is the cells are out of balance not the SOC percentage.
