zachwinter avatar image
zachwinter asked
Help connecting/configuring a second Cerbo GX (needing more resistive tank inputs)
I have two Cerbo GX units and am wondering if there is a specific way to configure the second (slave?) to show the tank inputs on the display connected to the first (main?) Cerbo.
The two units are connected via VE.Can (with a termination plug at both ends of the system), perhaps I should try VE.Bus?
The Touch 70 on the main shows a second device.
I turned on and configured the tank inputs on the slave by plugging in the Touch 70 into the slave.
Cannot figure out how to get the tanks plugged into the slave to show on the main unit.
cerbo gxHelptank monitor
zachwinter answered ·
