andrevv01 avatar image
andrevv01 asked
Generator fuel tank Cerbo GX
Hi
I have a question regarding using the cerbo GX to measure the generator fuel tank.
What would I need to add to the cerbo and is there anything specific to use with a diesel Generator? Is there as well certain peramaters regarding the fuel tank size?
Thank you in advance
cerbo gxGeneratortank monitor
mvas avatar image
mvas answered ·
Fuel Level Sensor ...
Fuel Sensor
Kevin Windrem avatar image
Kevin Windrem answered ·
To use the Cerbo's tank sensor inputs, you need a resistive sensor fitted to the tank. These are generally float-type sensors mounted through a hole in the top of the tank.
