gary-angove avatar image
gary-angove asked
Multiplus 12/3000/120-50/230-240V
Am I able to switch off the charger to enable me to use other 240v appliances. I use a Honda 2.2 generator. I am unable to charge and use the coffee machine at the same time. The generator is not big enough.
Mark avatar image Mark ♦♦ commented ·
I am also keen to know if there is a simple way to do this with a Multiplus assistant and a simple switch wired into one of the 'Aux In' terminals.
I have had a look at the assistants a while ago & think I found one that could limit/change the charger current, but not one to simply turn the Multiplus charger off & keep 'AC In' active to power the loads.
tilo avatar image tilo commented ·
Did you install the inverter or somebody else? Do you have a MK3-USB interface? Can you post your VE.Configure settings?
If I understand the question correctly, the DC charger can be disabled in VEConfigure.
https://docs.victronenergy.com/veconfigure.html#charger-settings
Hi Guy,
Yes I have also seen the 'Enable Charger' tick box in VE.Configure.
But we would like to trigger this on/off without having to pull out a laptop + MK3 to USB adaptor each time.
Ideally with a simple switch connected to 'Aux In' terminal's & using an assistant. I couldn't find such an assistant...
Any ideas?
Would a BMS related assistant possibly work?
Paul B avatar image
Paul B answered ·
Hi I just did a similar setup for turning a fan on and off
instead of selecting fan select charger and follow the sequence. and you can then put a switch across AUX1 to turn charging on or off etc
see the link below
https://community.victronenergy.com/questions/20665/external-cooling-multi-plus-123000-how-to-setup.html
