I want to use the Smartshunt on a negative 48V power line. Where do I put the smartshunt?
@garyk111 have a look at the Quick Install Guide.
As per diagram the shunt goes on the negative side of the battery.
All loads and chargers on the system side of the shunt. The only thing connected to the batteries negative is the Smart Shunt.
39 People are following this question.
