Victron Multiplus II’s built-in GX keeps going offline with a stable internet connection, it needs constant reset. Please advise.
Wifi or wired? If wifi, it can often be unstable or subject to interference.
The built in GX is inside a nice metal case of the multi which won't help with signal.
Are you also up to date on GX firmware?
You can set the GX to auto restart on comms loss under vrm settings.
33 People are following this question.
