Is it possible to have 2x a Multiplus-II 3000 in the same ESS, each drawing their power from the same battery and have them each on a different phase? Reason for this would be to be able to stay below the 16A rating of the fuses for each phase.
Yes, it's called split-phase:
https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
PS. I know I will need compatible models and therefore may buy both units at start.
Thanks!
84 People are following this question.
