Switching over to lithium. I have phoenix multi that was installed previously but has been in indoor storage for 8 years.
Installed wiring on the 12V side. temp wired the Victron. Fuses are all good. Connected to battery (charged to 13V). 120 VAC in connected.
Nothing happens. Toggled the switch both ways. Nothing.
No LEDs anywhere are lit.
No obvious damage anywhere.
Seems there should be some test points on the board.
I don't want to purchase new if this can be put into service.
