lurenut avatar image
lurenut asked
Orion-TR Smart 24/12-20A DC-DC - Boat Installation
I have a 24v 200ah lithium boat battery which I want to use to maintain full charge in a 12v boat starting battery using a Orion-TR Smart 24/12-20A DC-DC charger.
Questions:
1. Given the starting battery will also be charged from time to time from an outboard alternator, can the Orion 24/12 stay connected while the outboard alternator is running ?
2. When charging the 24v battery via a 24v Victron Phoenix Smart charger, can the Orion 24/12 stay connected to the 12v starter battery ?
3. I assume the Orion 24/12 should be set to the Charger (not Power Supply) Setting ?
4. Should the Engine Shutdown Detection setting remain enabled or not in the settings ?
5. Anything else I should be aware of ?
Appreciate any assistance or advice.
Cheers
Rob
orion dc-dc
kevgermany avatar image
kevgermany answered ·
1-2 yes
3 depends
4 depends
5 you have a couple of options. One is to set it to power supply, shutdown detection disabled and output voltage set to float voltage for the starter battery. The other is to enable engine detection, set charger mode and set these parameters so that the Orion recognises the phoenix charging voltage and charges the starter at the correct settings. Easiest is probably the first option. But you'll need to make sure the lithium gets charged regularly.
lurenut avatar image lurenut commented ·
Appreciate your response, many thanks !
