nishad avatar image
nishad asked
GuiMods installation error on VenusOS 3.00.39
@Kevin Windrem Is there more information needed to diagnose the issue? This is 3.00.36 to .39 upgrade.
root@FlyingCloud:~# /data/GuiMods/setup
--- starting setup script v7.46
creating file set for v3.00~39
ERROR v3.00~39 dbus_systemcalc.py no replacement file
ERROR: incomplete file set for v3.00~39 - can't continue
Package Manager, SetupHelper, ShutdownMonitor, RpiDisplaySetup, RpiGpioSetup got upgraded with no apparent issues.
Venus OSgui mods
Kevin Windrem avatar image
Kevin Windrem answered Ā·
There is a new version of GuiMods (v7.47) that will fix this issue.
nishad avatar image nishad commented Ā·
Thank you!
Also, thank you for all the work with GuiMods and your contributions to this community.
0 Likes 0 Ā·
nishad avatar image
nishad answered Ā·
Does not seem to want to install. Is there a trick to it? I tried uninstalling and reinstalling.
v7.47 should be compatible with the latest beta (v3.00~38) and SOME of the previous betas, but you should be on the latest beta. Should not be an issue with the released version (v2.94) either.
Generally, this problem comes if something modifies one of the files the package needs to replace. If no match in the file sets can be found, the "incompatible" message shows up.
You can get details in the log files:
/data/log/SetupHelper
data/log/PackageManager/current
Try switching to backup firmware and installing the current release or release candidate again.
derrick thomas avatar image derrick thomas commented Ā·
@Kevin Windrem your previous post you mention beta 3.00~38 but op is on current beta 3.00~39. was that a typo?
0 Likes 0 Ā·
Kevin Windrem avatar image Kevin Windrem derrick thomas commented Ā·
Yes, typo. Works on ~39
0 Likes 0 Ā·
Unsure why installation via Package manager in the Settings menu failed. Looks like it was still looking at 7.46 package. Executing /data/GuiMods/setup from terminal did the trick. Couldn't find anything interesting in the logs other than repeated 7.46 installation attempts in spite of 7.47 being downloaded.
0 Likes 0 Ā·
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
