nishad avatar image
nishad asked
Multiplus II 3kva/120x2 does not respond to on command from Venus OS
I have a multiplus II 2x120/12v/3kva that is connected to the Bluetooth dongle and a RPi running the latest Venus. I am also running the GuiMods. I can never turn on the inverter from the VenusOS UI. I can using the Victron Connect app. Once turned on, all controls on the UI for the inverter/charger works including turning it off.
What are the best steps to debug this issue? Are there any logs I can provide?
Multiplus-IIVenus OSgui mods
nickdb avatar image
nickdb answered ·
The first thing to do is remove all modifications and see if the issue persists.
nishad avatar image
nishad answered ·
I just did a clean install of VenusOS. This behavior reproduces with stock VenusOS image as well. Baffling!
