jonathanv avatar image
jonathanv asked
Phoenix Inverter Control and remote on/off
I have the old style Phoenix inverter remote control panel (UTP) and a Phoenix 3000W inverter. Is there a creative way of having both the remote control panel working and be able to have a BMS turn it off through it's remote on/off? I know the manual states it's either the remote on/off or the remote control panel but perhaps I could splice something into the UTP cable that would enable or disable it?
Phoenix Inverter
Mike Dorsett avatar image
Mike Dorsett answered ·
The remote on/ off is usually a switch wired up to the inverter. If the BMS has a volt free relay used to enable / disable load circuits (most of them do) then this relay can be wired in series with the remote switch.
jonathanv avatar image jonathanv commented ·
Thanks, in this case the remote control panel has a few additional features, like a set of status lights.
https://www.victronenergy.com/panel-systems-remote-monitoring/phoenix-inverter-control
And the UTP connections on the inverter are also used to sync multiple inverters, so I am not sure if it's just a simple wire to break or if the control panel is more intelligent.
klayman avatar image klayman jonathanv commented ·
Did you find a solution to this? I'm looking to do something very similar and am wondering if it's possible to use both the remote panel as well as the Remote H/L input driven by the BMS ATD signal.
I know that the manual states only 1 can be used but it seems very odd that this would be a hard limitation. What happens is both are connected? Does 1 take preference over the other or does 1 just not work at all?
