yes, this is how it should be. The battery can only save limited amount of energy. When the battery is charged and you have no other energy consuming loads, the panels full power is not used and therefore the Amps/power from panels will decrease the more the battery gets charged.
When the Battery is completely full and all loads are off, power production should even go near zero.
Regards,
Markus
Markus
Thank you for verifying this
Wonderful to have such an accurate measurement. Find it really helpful if out for several rainy days.
7 People are following this question.
