iam22lr avatar image
iam22lr asked
Conversion 12v to 48v
Hi, anyone have a recommendation for a 12v to 48v converter? Was looking at the Orion DC-DC Converter, seems like its what I need but not 100% sure. Specifically, I am looking to power my Starlink satellite via 12v. I have seen a couple of options on Amazon but they don't instill much confidence, if Victron has a solution I would likely end up with that. You can view a blog post online on what I am looking to do - my setup would be slightly different as I would not setup a router but it provides a good overview of what I am looking to do. Appreciate all suggestions.
orion dc-dc
4 comments
nesswill avatar image nesswill commented ·
Do you have a 12v system or 48v?
12v to 48v ? but as you say " I am looking to power my Starlink satellite via 12v" or 48v to 12v ?
i use the Orion-Tr 48/12-9 ??
kevgermany avatar image kevgermany ♦♦ nesswill commented ·
Starlink needs both 12 and 48V, 12V must be reasonable (i.e. not subject to charger voltage levels)
nesswill avatar image nesswill kevgermany ♦♦ commented ·
ta got it.
jd-travelers avatar image jd-travelers commented ·
I too am looking for a 12V to 48V orion for alternator charger. My camper is built on a 48V, which is becoming more popular. Any updates on this?
Thanks
kevgermany answered ·
Orion would be ideal. Make sure you get the correct one. 12/48 gives 48V from 12. Last number in the spec is max sustained output current.
You might have seen the Everlanders YouTube channel. Some starlink hacks there which may help.
ejrossouw avatar image ejrossouw commented ·
Victron does unfortunately not offer a 12/48 https://www.victronenergy.com/media/pricelist/Pricelist_Victron-Euro_C_2023-Q2_WEB_1.pdf or have one listed in the ordering system from I could see.
kevgermany avatar image kevgermany ♦♦ ejrossouw commented ·
Thanks. I thought from the original post that he had found one. Clearly not.
iam22lr avatar image iam22lr ejrossouw commented ·
Thank you.
