For sanity...I wanted to confirm the maximum input current (24V side) on the Orion DC-DC Converter - 24/12-70A is ~35A. Correct?
Roughly correct, though depending on overall circuit efficiency it will be slightly higher. The 24/12-70 is about 92% efficient, so supporting a 70A load on the 12V side you'll likely see between 37-40A being pulled from the 24V side assuming that wiring and circuit length has been spec'd appropriately.
Victron DC to DC Converters Product Range
__________
31 People are following this question.
