iammotorhomeless avatar image
iammotorhomeless asked
Has anyone had their G99 A1-1 approved in less than 15 hours
HI
I am sorry, I feel as if I am bragging.
But everything I had read about G99 forms was super scary and stressing me out loads.
And I just wanted to share, I followed the guidance found in other threads and submitted my G99 A1-1 form to my DNO, (NG or was WPD) via email at 8:30 pm last night, and at 11:30 this morning I got my approval
Has anyone got theirs back quicker than that ?
it's not that hard or scary, you don't need to pay someone hundreds of pounds to do it for you.
unless you want too.
I am installing a Multiplus II 48/5000/70-50 230V with a 5kW 48V battery and a small solar PV system
Below is the main part of the G99 A1-1 form and my line diagram (a modified version of the one craigc posted)
I also attached the new 31 Mar 2023, G99 test certificate issue 1 amendment 8 (PDF Document - 857 kB) off the Type Test Registery.
It was as simple as that...
HTH, someone
Multiplus-IILithium Batterysolardno certificationg99
iammotorhomeless avatar image iammotorhomeless commented ·
And... we only have a 60A main fuse.
they offered to upgrade it to a 80A fuse, free of charge
Craig Chamberlain avatar image
Craig Chamberlain answered ·
Glad to hear you got a good result. FWIW the landscape has changed a lot in recent months with some reforms to the G99 process (SGI-3) and the compliance of the Victron inverters. It also still varies a lot by DNO with my DNO SP Energy Networks being particularly slow and pedantic it seems.
When I started my G99 journey back in September, my first application just got rejected flat out due to the inverter compliance having just been revoked. I then had a series of emails back and forward with an average response time of 2 weeks each time, and constant clarifications and corrections. That’s when I decided to get g59projects involved because I just couldn’t be bothered with this distraction when I had too many other demands on my time.
Even then I took SPEN about 6 weeks to reply with my offer letter which was accompanied by a “design fee” demand of £300. This was even though there was no network reinforcement needed! I intend to contest this fee but paid it at the time just to get things moving. At that point the inverter was still not fully compliant so I didn’t want anything to give them an opportunity to change their mind!
Anyway, this is part of the problem - it’s just so inconsistent.
Very happy for you.
Yes, and thanks again, I think it was your line diagram that won them over
me too, I started looking at it all late last year.. And it was only when I was ready to buy the Multiplus II 48/5000, did I realize that it's compliance had been revoked. So I have spent the last few months waiting, watching... and thinking that like you, I would then have to wait for the DNO to approve my install
I have had my batteries for months, but the Victron gear, Multiplus II, 500A shunt, Lynx and ET112. And cables, and other stuff all arrived this week.
I am ground mounting the Solar, just 2 panels to start with, The galvanised tube and key fittings just arrived today. the solar rails are on backorder, (hopefuly next week)
and then I will order the two Sharp 540watt half-cell solar panels
that should keep me busy
pauldunn avatar image
pauldunn answered ·
I need to apply for G99 with Northern Power Grid so thanks so much for sharing this. I am curious though, where does the 4.4kW generating capacity come from? Isn't the MP 2 5000 only 4kW?
Ideally I want to get a approval for 2 MPs in parallel, would that still be the same form? Is there a source document for this diagram that I can edit to show 2 MPs?
daza avatar image daza commented ·
No the rating 4.4kW is from the ENA you can see it on the ENA website which is what the DNO use. My DNO was really straight forward everything online and then upgraded me to 100amp on my request then approved connection to the grid and gave me till June next year to commission. They where not as scary as some sparks make out lol
sharpener avatar image sharpener commented ·
Yes, the data sheet shows 4.0 kW @25C but IIRC when grid connected the figure is for some reason 4.4kW. Have just checked again in the data sheet and manual and cannot find it there but I think it is authoritative.
Here is an extract from the certificate:
cookiedude avatar image
cookiedude answered ·
Wow.. impressive.
Did you self install? If so (as I am thinking to) what did you put for:
Installer details:
Accreditation / Qualification
Is None a valid answer? Or do you (or anyone) know if I can put my local electrician (NICEIC Approved) as they will be doing the wiring for connecting it to the grid...
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
Battery Compatibility
