sneruh avatar image
sneruh asked
2s2p mid point voltage connections and smart shunt
I currently have two 12v100Ah in series to my Multiplus2a/2000/120V . I am upgrading to four 12v100ah LiFePO4 batteries in a 2p2s configuration. The SmartShunt manual doesn't seem to cover where to connect the Vbatt and Aux wires for a mid-point configuration. Would this be correct? And if so, I suspect that the mid point voltage would not be for each battery but rather for each two series set, right? Side question: Do I really need busbars?
SmartShunt
mvas avatar image
mvas answered ·
If you fused each bank individually, then there is no midpoint jumper. You can connect the vbatt and aux wires to batteries in one bank.
