mikeb avatar image
Ve Bus Error 17 with CCGX?
Hi
Can I ask a question to all the guys with intermittent Ve Bus Error 17 ‘s
Do you have a gx installed ?
And how are you all restarting the system after the error?
I have a colour Gx running the latest firmware 2.30 and 2 10kva quattros on a Byd b box setup
Before the error there is nothing to suggest why the master turns off
And I am able to restart the system on the VRM via the remote inverter on off
Regards
Mike
BYDVE.Bus
Hi Mike,
There was indeed an issue with the CCGX and systems with more than one Multi.
There is a fix available. Currently being tested as a release candidate:
https://community.victronenergy.com/questions/22580/venus-os-v2323-available-for-testing.html
1 comment Share
Hi
I have been made aware of the update but haven’t installed it yet
The reason being is the last error I had was on the 28th of may 3 weeks after replacing the inverters for two new ones
The system was reset on the 28 th of may and on the 2nd of June some ferrite’s places on the ac inputs and outputs of the inverters see pictures and have not had it error to this present date?? Which to note is the longest time between error 17’s
The ferrite’s on the Venus cables were there previously and didn’t stop the error 17
So not sure if I have found a fix at all by doing what I have done
As perviously I was able to get it to error 17 within 10 mins with only a AC to dc adaptor plugged in (which I find to much of a coincidence.
Will update to the full 2.32 firmware when it officially comes available but want to see how long the fix I have lasts
Regards
Mike
