phong le avatar image
Easy Solar and BYD installation issue
Hi there.
My solar sparky tried connecting and configuring my Easysolar (48/5000/70-100 MPPT150/100) and BYD (B-BOX Res 10.24kwh) and 12 Qcell panels setup but had the following issue:
"There is a slight short from Negative on the battery isolator to Positive on the inverter DC battery bus of 148.7 Ohms."
He can't seem to find support from anyone so i was hoping someone here could assist?
Thanks
Phong
EasySolar All-in-OneBYDinverter current draw
byd-service avatar image
byd-service answered ·
Have you confirmed if the short is on the battery or inverter side?
Thanks. Sparky says the short is on Inverter, batteries work fine until connected to the inverter.
Cheers
