tedrick avatar image
tedrick asked
phoenix 24/5000 inverter remote
Hi have a phoenix 24/5000 ve bus inverter followed instructions as per manual removed black jumper wire and fitted 6m wire about nine meters to switch in house turned it on blue light came on could turn it off and on packed up tools ,checked and inverter light was off had to put jumper wire back to run inverter again, Is the wire run too long Thanks in advance Ted
Phoenix Inverter
