peterb381 avatar image
peterb381 asked
Victron Orion 12/12 30 Charger - what should be included in the box?
Hey guys, I recently purchased the Victron Orion 12/12 30 Charger - installed it - set the parameters, and took the vehicle for a test drive without success, i.e. everything appears to be functioning via the app - but the unit wont turn on? So investigating what could be the cause, I discovered it needs the green bridge connection (minimum) or it will never turn on -- problem is, mine didn't come with the bridge and the manual doesn't have an 'items included' page -- so I'm not sure if I've been duped with a 'return item' or they don't come with them new? Can someone please confirm - I'm meant to be heading off on a trip this Friday, so I'm really desperate to know. Many thanks in advance, Peter
chargerorion dc-dc
nesswill avatar image nesswill commented ·
peterb381 avatar image peterb381 nesswill commented ·
Indeed @nesswill - thank you very much sharing that. From yours, and others, feedback - it looks like I lucked out. Cheers Peter
Alexandra avatar image
Alexandra answered ·
@peterb381
This is how the product looks out the box.
See this unboxing video at around time stamp 1:30 to 1:45.
peterb381 avatar image peterb381 commented ·
Thank you very much Alexandra - it's now categoric. Really appreciate you taking the time to post that, looks like I'll be emailing the company - and hopefully - acquiring one from somewhere locally in the meantime (as I need it be Friday). Cheers Peter
luphi avatar image
luphi answered ·
It definitely should come with the bridge.
Thank you @luphi - I'm now on the hunt for one - I believe this should be the same: Jaycar 2 Pole Pc Mount - fingers crossed. Cheers Peter
jamesw avatar image
jamesw answered ·
peterb381 how did you go. I might be in the same boat
Simply bridge the two connections with an insulated wire. 0.5mm square would work, there's effectively no current.
But probably these are returns that the seller is passing off as new.
Hey James, no doubt what @kevgermany said is correct. In my case, I was lucky enough to be travelling with a mate who had one of these 2 Pole Mounts (...he seems to buy everything from Altronics, though I know Jaycar sells them, too; apparently, it's a universal plug) - anyhow, once installed, it most definitely worked ;) -- Good luck!
Victron DC to DC Converters Product Range
__________
Chargers.
