steve-carter avatar image
steve-carter asked
Energymeter ET112 - change baud rate on the CerboGx
I have a Victron Cerbo and I run a couple of Energy Meters on it - each with its own address; connected via a Victron RS485 USB adaptor. I note that the baud rate is 9600. I am aware that I can change the ET112 baud rate to as high as 115200 via the Carlo Gavazzi UCS software. How can I change the baud rate on the Cerbo GX to match it? This would potentially allow me to run other devices on the same RS485 adaptor as long as they all had different addresses and the same baud rate.
Energy Meterrs485
Energy Meter Selection Guide
