dhatherton avatar image
dhatherton asked
Change out of Converter/Charger
I have a Schumacher Electric Corp. Converter Charger Model RVCDP55 input in a Motorhome. I'm switching to 2 Dakota 12V lithium batteries for the coach. 120VAC 60HZ 1000 watts, output 13VDC 55 amps. I'd like integrate solar panels into the system also.
battery chargingsmart solar set-up help
nickdb avatar image
nickdb answered ·
Hi, is there a question lurking in here somewhere? Nothing of what you have stated so far is a Victron product. Are you looking to change if so, please provide a bit more info and I am sure someone will help.
VictronConnect VE.Bus charging manual
