palli avatar image
palli asked
BMS goes crazy when rebooting Cerbo.
Has new 48v system with Rec Q-bms. When I reboot the Cerbo GX, error code 8 comes up on the bms and the temp sensors alternate between the correct temperature and -999.9, first one at a time and then both, continuing until I turn off the system. While behaving like this, the relay contact pulses and the relay turns on and off every second. When I turn off the bms, the pulse stops after about 1 minute. Is this something I can change in the program on bms, or is this an error in it?
BMS
palli avatar image
palli answered ·
New software in MultiPlus 2 had a conflict with digital temp sensors in bms. With new firmware for bms, everything works as it should.
palli avatar image
palli answered ·
Here is a picture of the system, the relay is of the type Tyco EV200ADANA.husið-1.jpg
What is sending the error the ve bus or the mppt?
palli avatar image palli Alexandra ♦ commented ·
BMS gives an error. I received information from the manufacturer that there is an error in the program and he gave me guidance for upgrading.
