I’d like to be able to switch the relay on our Buck Boost to turn it off after the batteries reach a set voltage. Can this be done with the Smartshunt, from the aux port?
No. The aux connection on the smart shunts is an input only, for use with a temp sensor or to monitor the voltage of an auxiliary battery.
38 People are following this question.
