fretief avatar image
fretief asked
Smartshunt SOC suddenly jumps to 100%
Smartshunt 500 connected to a 100 Ah 12V Lithium battery. Consumed Ah was 73.1 and SOC showed 27%. I then connected a Victron10A battery charger and the system charged up to just below 40% and then jumped up to 100% SOC. Actual battery charge is below 40% and not 100%. This is confirmed where battery charger shows it charged only 12 Ah.
SmartShunt
fretief answered ·
Here is the charge graph and Battery settings
Nev avatar image
Nev answered ·
Your charged voltage set to 13.2V is far too low and will prematurely synchronise a 100% SOC reading after 3 minutes. The battery will be nowhere near full.
Mine is set to 14.1V and the Charge detection time to 3 minutes at which point my 4 cell 300Ah LiFePO4 battery is always full.
Perfect operation for the last few years.
kevgermany avatar image
kevgermany answered ·
Also if your normal charging is from solar, consider increasing the detection time to cater for clouds lowering the charge rate.
