bkiesbauer avatar image
bkiesbauer asked
Eastron SD272DM-V2 Meter Venus OS driver
Energy Meterdriver
Christian Butterweck avatar image
Christian Butterweck answered ·
Hi @bkiesbauer I am trying to test your driver. I copied all the files to the directory and rebooted. Its not showing any data, how can i set up and check the correct USB device?
Regards Christian
root@raspberrypi4:~# ls -l /dev/serial/by-id
lrwxrwxrwx 1 root root 13 Jan 1 1970 usb-FTDI_FT232R_USB_UART_AB0MGIOW-if00-port0 -> ../../ttyUSB0
lrwxrwxrwx 1 root root 13 Jan 1 1970 usb-VictronEnergy_MK3-USB_Interface_HQ21327P2VK-if00-port0 -> ../../ttyUSB1
Mar 20 00:09:06 raspberrypi4 user.info kernel: [ 4.654387] usb 1-1.2: Detected FT232RL
Mar 20 00:09:06 raspberrypi4 user.info kernel: [ 4.690514] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
EDIT:
Its working now. I had to swap A&B again on one side and configure the baud rate on the meter to 19200, the default password is 1000 by the way if anyone else needs it.I am now using the following:
Counter: https://amzn.to/3LBlkum (currently only costs 51.50 EUR)
RS485 USB adapter: https://amzn.to/3Jw5lL8 (the version with FT232RL chip, currently 18.50 EUR)
So why spend so much on an ET340 that doesn't even have a display?
@bkiesbauer
Short Feedback:
L2 and L3 need to be swapped within the driver so that it will fit to the meter display.
Regards Christian
teasy avatar image
teasy answered ·
Hi @bkiesbauer,
thanks for the adapter. Works in principle, but with different sign the displays are not correct for me. With L2+L3 the sign is missing at the current and the sum is formed incorrectly. With different signs of the representation in the picture is not correct at all.werte-sdm72.pngbild-sdm72.png
Do you have an idea?
sevensworld avatar image
sevensworld answered ·
Is it still working with 3.13 oder 3.20 ?
Energy Meter Selection Guide
