Is it possible to turn "OFF/ON/Charger only" on MultiPlus via GX device when using a VE-BUS BMS V2?
Hi, it should be but in my situation with a Quattro+Mains detector+BMS V2+Cerbo GX all updated to latest firmware do not work: the cerbo GX acts like if you have connected a BMS V1 and do not allow you to turn "OFF/ON/Charger only" on the QUATTRO I also Have a second problem DVCC do not recognise BMS V2 and do not control for example solar chrgers also for this problem CERBO probably see BMS V2 as a BMS V1 so nothing work
This is probably a software issue of the CERBO but also Victron Support do not have a solution
38 People are following this question.
