grimbo avatar image
grimbo asked
Cerbo to GSO CANbus BMS pinout
240a7050-96a0-4a52-8f04-5d34935a3080.jpeg1f0df76d-c4fc-4f47-8f59-97052f28126e.jpegI have installed x5 GSO li-ion 200ah 48v to Quattro 48/10000 via lynx 1000 with Cerbo.
It works as it should but I’m trying to get a pin out schematic between the batteries and Cerbo. I struggle in this area and any help is appreciated. Included is a pic of the batteries can pins. Thanks.
BMS
Alexandra avatar image
Alexandra answered ·
@Grimbo
Pin outs can be found here.
grimbo avatar image grimbo commented ·
Thanks, for the grounds, the battery pin out does not show anything, would it be 3 and 6? This is where I get lost. Thanks
frankista avatar image
frankista answered ·
Good day. I have the exact same batteries from GSO (a total of five batteries of 200 ah each) mounted in parallel however I’m facing a major issue with their BMS. Every two to three days I have to reset the BMS (by turning them off and then on). The issue I face is that my inverters end up seeing one battery instead of all five as a result reducing the charge and discharge amperage. On the inverter I see the error 0x1000. I have recalled the whole thing to make sure that the batteries are balanced but this did not help.
Are you facing the same issue?
