Hi guys
Is there some way to show the kWh count for charging batteries from Grid or Generator? Can this be done via NodeRed/Signal K?
Thanks!
Hi guys
Thanks!
I'm using Modbus TCP with Home Assistant.
Take this for refference
https://www.victronenergy.com/upload/documents/CCGX-Modbus-TCP-register-list-2.90.xlsx
https://www.victronenergy.com/live/ccgx:modbustcp_faq
Here are the Unit IDs and Addresses for your counters:
Unit ID 227 Address 76 "Energy from AC-In 1 to battery"
Unit ID 227 Address 80 "Energy from AC-In 2 to battery"
Unit ID 227 Address 92 "Energy from AC-out to battery (typically from PV-inverter)"
#Home Assistant implementation modbus: - type: tcp host: 10.0.0.50 # use the IP address of your CCGX port: 502 name: victron sensors: - name: victron_energy_from_ac_in_1_to_battery_raw unique_id: victron_energy_from_ac_in_1_to_battery_raw unit_of_measurement: "kWh" slave: 227 address: 76 data_type: uint32 scale: 0.01 precision: 2 scan_interval: 60 device_class: energy - name: victron_energy_from_ac_in_2_to_battery_raw unique_id: victron_energy_from_ac_in_2_to_battery_raw unit_of_measurement: "kWh" slave: 227 address: 80 data_type: uint32 scale: 0.01 precision: 2 scan_interval: 60 device_class: energy - name: victron_energy_from_ac_out_to_battery_raw unique_id: victron_energy_from_ac_out_to_battery_raw unit_of_measurement: "kWh" slave: 227 address: 92 data_type: uint32 scale: 0.01 precision: 2 scan_interval: 60 device_class: energy template: - sensor: - name: "victron_energy_from_ac_in_1_to_battery" unique_id: "victron_energy_from_ac_in_1_to_battery" unit_of_measurement: 'kWh' state_class: "total_increasing" device_class: "energy" state: "{% if is_number(states('sensor.victron_energy_from_ac_in_1_to_battery_raw')) %}{ { (states('sensor.victron_energy_from_ac_in_1_to_battery_raw')) }}{% endif %}" - name: "victron_energy_from_ac_in_2_to_battery" unique_id: "victron_energy_from_ac_in_2_to_battery" unit_of_measurement: 'kWh' state_class: "total_increasing" device_class: "energy" state: "{% if is_number(states('sensor.victron_energy_from_ac_in_2_to_battery_raw')) %}{ { (states('sensor.victron_energy_from_ac_in_2_to_battery_raw')) }}{% endif %}" - name: "victron_energy_from_ac_out_to_battery" unique_id: "victron_energy_from_ac_out_to_battery" unit_of_measurement: 'kWh' state_class: "total_increasing" device_class: "energy" state: "{% if is_number(states('sensor.victron_energy_from_ac_out_to_battery_raw')) %}{ { (states('sensor.victron_energy_from_ac_out_to_battery_raw')) }}{% endif %}"
69 People are following this question.
