rival avatar image
rival asked
Phoenix Compact Victron Multiplus Inverter Charger 24/1200/25... not working at all!
I have a 24v off-grid solar system on-board my Barge... installed about six months ago. All was working fine until I installed an electric water pump which tripped the shore line AC breaker and now the inverter is dead! Checked fuse but no luck... I did notice that when I toggle the inverter main switch – the LEDs flash on briefly. The inverter is old, but maybe it can be fixed? Any help would be appreciated.
Phoenix Inverter
kevgermany avatar image
kevgermany answered ·
AC water pump?
Is it still connected?
Have you tried complete power off/AC and battery disconnect, reconnect after a few minutes?
Otherwise it's unit to a dealer for repair. They'll advise if it's still repairable/worthwhile.
