tochal avatar image
tochal asked
do i need a Smart shunt?
i am building a 3 Phase ESS system using 3 Multiplus 3000 + Cerbo Gx.
i have already a Daly BMS + interface board to connect it to GX, if it works or not, i cant say, since i haven't don it yet
- do i still need a Smart shunt?
- what does a Smart shunt offer me? just monitoring or also protection?
- if it does also protection, which protections? over current? over/under voltage? over/under Temerature?
thanks in advance
SmartShunt
wkirby avatar image
wkirby answered ·
You need a battery monitor in the system.
If the Daly can present its self as a battery monitor to the system then you can use that. It difficult to say if the Daly will work like this since it is not a supported BMS type.
If the Daly does not presnt its self as a battery monitor to the system then you would need to use a SmartShunt or BMV.
A SmartShunt is a monitoring device and does not offer any protection mechanisms it's self. A BMS is intended to perform the battery protection tasks.
tochal avatar image tochal commented ·
thanks for the answer, i didnt mean that Shunt on is own does protection, i meant if Cerbo+Multi , with the information which comes from Shunt, perform a protection ?
