Herve RV Nizard avatar image
Herve RV Nizard asked
What is the pass through capacity of the Easysolar?
The AC Out port 0 of a easysolar 1600/24 is for loads to be supplied only when AC IN is available. Is this port a complete bypass of the inverter or not ? In other terms , will the loads be limited tothe inverter's capacity (1600 Va) or will it be able to supply loads directly from the grid ? I wish to keep one socket in my system to eventually connect a large tool from time to time (grinder, power saw...) without it draining the battzries or be limited by the inverter's capacity. I have AC IN available. Thanks .
EasySolar All-in-OneAC PV Coupling
JohnC avatar image
JohnC answered ·
The Passthrough capacity of each unit is listed in the data sheets.
For your unit it is listed as Heavy Duty Output AC 0 = 16A
Your unit should passthrough 16A @ 230V without being limited by inverter capacity.
