rbeudel avatar image
rbeudel asked
MPII Low Battery LED flashes
Hello, because of the trouble with my Daly BMS I disconnected the BMS from Victron OS on raspi and escaped all informations out of VRM and Victron OS. In the same time I did the firmware update of the MPII to 502. Since this time I have battery warning flashing, but the voltage is over 52V. In the VRM and in the Venos OS is no current Alarm present. Only the red flashing LED will displayed and in the Alarm Status of the MPII the battery warning is present. I started everything new for several times, but always the battery warning comes back. What shall I do?
Multiplus-IIlow battery warning
arjun-suhass avatar image
arjun-suhass answered ·
it sounds like you may be experiencing an issue with your MPII inverter or Your Daly BMS. Since You recently updated the firmware on Your MPII, it's possible that the issue is related to the firmware update.
rbeudel avatar image rbeudel commented ·
The inverter has no more data communication with the bms. When I load the battery with the ESS Function Time Sheduling (German planmässiges laden), the low battery LED will go out.
