powergraphy avatar image
powergraphy asked
EasySolar 2 Gx in Camper
Hello community,
I am currently working on a plan for my camper van build and I recently found the EasySolar 2 GX, but some questions are unanswered for me. Maybe you can help me.
My biggest concern is if one element of the device fails, for example the MPPT, is the rest of the system still working or is the whole electricity setup shut down? Is it possible to repair or replace one element if it breaks or do I have to buy a whole system again? (Or have it repaired if it breaks in warranty.) Can I do this by myself or do I need a professional for that? Is it possible to turn the inverter of but still have the ability to charge the battery?
Thank you in advance for your answer or tips.
Martin
EasySolar All-in-Onecampervandiy
kevgermany avatar image
kevgermany answered ·
MPPT is simply a normal MPPT built in. Cover off and you will see it. Effectively it's a separate unit. So MPPT can fail and you lose solar, bit nothing else.
Repair is always by Victron. They will want the whole unit. Replacement at their discretion, depending on the fault.
The inverter/charger is a single unit. But there's a charger only setting.
powergraphy avatar image powergraphy commented ·
Thank you for your answer. :)
EasySolar 1600 product page
EasySolar-II GX 3000 & 5000 product page
