gewoonpeter avatar image
gewoonpeter asked
SmartShunt in VRM don't show up in VRM
Hi I'm Peter,
Since last week i've added a SmartShunt to my Victron-network.
Next to my: MultiPlus 3000 and MPPT 100/50 all in 12v @ 300A LiFePo4
The SmartShunt is setup as "EnergyMonitor" and i've tried diferrent sub-options, like: Fridge, Boiler, DC-SYSTEM, ect.
But the problem is that the Shunt doesn't appear at my VRM Dashboard.
The device is by USB-connected to my Venus OS, what it also detects.
I see the wattage in my Advanced-panel. But not in the main Dashboard.
I added this SmartShunt to monitor my 12v-users, like: lights, fridge and blower.
Can somebody help to show the Shunt into my dashboard?
Advanced, shows:
Dashboard doesn't show:
Device is added (and re-added, and...) In like 4 different ways/"names"
SmartShunt
pwfarnell avatar image
pwfarnell answered ·
You need to tell your Venus OS device that you have a 12V system with loads on the system on the "System Setup" menu, see image, select " Has DC system" to On.
Then you should get the extra box, I do not know how long it will take VRM to synchronise to the new addition.
gewoonpeter answered ·
Thank you for your reply!
But this is not what i'm looking for.
The Shunt as to monitor the watt-usage from a particular circuit, like i selected for example: Fridge.
The "Has DC System" is in my case, the car-dynamo who powers also, when i'm driving.
So I expect a new tile with "DC consumers" of with the selected name: Fridge
Screenshot:
What I think it does (wrong):
- AC-power minus the "Shunt output"
In fact I use now not 9w but still around 40-50w in AC and in DC for real 10-30w
So it seems to be a mistake by the automatic system? 40-30 = around 9w ?!
The dashboard is now a bigger mess...
Sorry I misunderstood, I think Victron have not got the displays for DC energy meters working so you can not see a separate tiles for each user.
No problem, thank you a lot for thinking with me!
This article talks about, what I want to achieve:
https://shop.pkys.com/Using-the-Victron-SmartShunt-or-BMV-as-a-DC-Ammeter_b_193.html
What I think is..
- Shunt measure it (right + all good)
- Shunt shows it right in VRM Advanced
- VRM understand this in the wrong way:
- it calculates wrong, by AC - DC = consumption ?!
- it doesn't show up as own tile
--- update, i will change my complete setup with 2 new devices: BMV712 and DC-DC Orion
