pachis avatar image
pachis asked
Contradiction in Manual MultiPlus-3k-120V-(firmware xxxx4xx)-EN
In Appendix A the diagram shows the AC in connections at block A. These show as [left-to-right] line, neutral, ground. In the manual next page, the description for block A says the left-to-right order is "ground, line, neutral.
Which is correct?
Thanks,
PACHIS
Phoenix Inverter
abrahamsolar avatar image
abrahamsolar answered ·
Hi, Pachis, from the USA. It's always good to report an error in the installation documents.
When there's any uncertainty, I always go by the legend that is imprinted onto the actual circuit board inside the unit.
Thanks for reporting it, I will see that it’s fixed.
I can’t confirm the correct layout, please go by what is printed on circuit board.
