Is the unit short-circuit proof, or is a separate fuse required at the output?
Thanks
PKingo
Thanks
PKingo
Best to fuse the output positive, this will protect the wires. If you're charging a battery fuse at both ends, otherwise a single fuse as close to the Orion as possible.
Victron DC to DC Converters Product Range
__________
31 People are following this question.
