glynn avatar image
glynn asked
Reverse polarity question
Hi, I have a Victron Phoenix Multi 12/2500 120. The reverse polarity light an a panel is lit up but only when on Inverter mode ( Not on Shore Power ) Although the inverter is working as it should it seems. I removed the front cover and noticed there are 2 fuses, one being a large flat bolted in fuse, the other looks like a cylindrical car type clip in fuse. I did a continuity test on this clip in fuse and got no reading. Could this fuse be causing the reverse polarity light issue, although the inverter appears to be working ok ??.
My electrician called someone at a Victron tech support place and they told him the way its working is correct.
I need to know what this fuse is for, there is no reference to it in the book.
Thanks in advance.
victron products
Paul B avatar image
Paul B answered ·
Its a guess replace it and see, the small fuse maybe for the secound battery charge connection if you inverter has it.
