tinos avatar image
tinos asked
HV Battery on PV input from Multi RS Solar 48/6000
Is it possible to connect my 300V HV Battery from an e-Vehicle to the PV input from Multi RS Solar 48/6000? I want to make an onGrid zero regulation out of my eVehicle battery. I don't want to use an 48V battery at the battery input. Is this working?
multiple inverters
Paul B avatar image
Paul B answered ·
its NOT RECOMMENDED BY VICTRON, however others have done it with the smaller mppt units and i do not know about your RS unit. so in threroy it should work.
do not exceed max pv voltage
