Todd Wackford avatar image
Todd Wackford asked
Can Multiplus use temperature and voltage readings from MV-712 thru Venus Device?
Can Multiplus use temperature and voltage readings from MV-712 thru Venus Device? If so, how do you set it up?
MultiPlus Quattro Inverter ChargerBMV Battery MonitorvoltageTemperature Sensor
Mark avatar image
Mark answered ·
Yes, using the Venus device menus enable DVCC, then enable SVS (shared voltage sense) & STS (shared temperature sense).
4 comments
Would it also work with a CCGX?
Yes, no problem.
Just go into the settings and activate DVCC, then SVS and STS.
I already did that and couldn't make it work properly, maybe my multiplus is dead. I made a separate question for my case, I would really apreciate if you could look at it.
https://community.victronenergy.com/questions/30767/can-i-use-dvcc-with-ccgx-bmv-700-and-multiplus-com.html
To keep the discussion on track, I have provided you with an answer in your post - please refer to that.
