bob1606 avatar image
bob1606 asked
Using “Programmable relay” depends on battery temperature?
Dear community,
a short introduction of my system: I’m issuing a MultiPlus-II 48/5000/70-50 GX with a 16S lifepo4 Batteries and Fronius inverter as an ESS system.
The goal is, to use the Multiplus relays to control the battery temperature.
But, first issue is, I don’t see the relay button in my remote console. Do I need to activate relay option somewhere in the settings?
I also tried to use the “Programmable relay” assistant but without success so far.
The idea is, to use the ACOut 2 relay to power a heating pad depends on the battery temperature.
Temperature <5° --> relay on
Temperature >10° --> relay off
Did someone this kind of setup and can support me?
Thanks
Multiplus-IITemperature SensorRelay
Al avatar image
Al answered ·
@bob1606
The temperature sense input won't work, it's just being used as a digital input rather for that programmable relay, it doesn't use the temperature measurements.. You could use something like this: https://amzn.eu/d/hMwD8tX
What bms do you have, does that have programmable outputs to trigger something?
bob1606 answered ·
Thanks Al for the quick reply. I use the JK BMS.
Maybe it is possible to make this setup with Node-Red. I just started with Note-Red tutorials. But maybe someone has already done this before and can send me a screenshot.
Thanks in advance
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
Victron temperature sensor disambiguation table - which product supports which sensor
