alex-la-mela avatar image
alex-la-mela asked
PYLONTECH+CERBOGX+SMARTSOLAR AND ANY NOT HYBRID INVERTER
Hi, I have a pylontech us5000 48v/5000 connected with cerbo gx and a smart solar mttp charger connected by ve.bus .
I have also a 5000w made in china inverter without any bus (it has only 4 line, 2 for battery connect and 2 to output 220v) and i have an old victron phoenix inverter without bus. Can I connect Pylontech battery to my inverter only using Vcc e Gnd Lines?
cerbo gxPhoenix InverterPylontech
@ALEX LA MELA
Not supported.
Is this for a data connection?
You realise that the Pylontec should only have comms with one system?
If you want the system to switch off the chinese one, why not use a relay from the cerbo?
alex-la-mela avatar image alex-la-mela Alexandra ♦ commented ·
Thank you Alexandra,sorry for my bad English,i explain my question, i don't want monitor any communication between my made in cina Inverter and Pylontech battery.
I want Pylontec communicate only with cerbo Gx and Mppt Smartsolar. Can i do it?
In this specific case, is data communication between Pylontech and the inverter mandatory or can it be avoided? Thank you
Alexandra avatar image Alexandra ♦ alex-la-mela commented ·
@ALEX LA MELA
Yes with the cerbo directly. It can connect see the victron Pylontec page.
The US 5000 use the type a cable from victron.
