Hi
Can I use a 220v relay like this to control the remote port on my Phoenix 12/1200 inverter?
https://heschen.com/products/hs1-25-2p-220v
/Mattias
Hi
/Mattias
Hi, yes is possible to use this relay for the application you need.
Is possible to use a little switch to, is a low voltage pass on this jumper.
toogle switch
37 People are following this question.
