On 3 of 7 VRM instances I can no longer add or remove widgets under any of the devices listed. All 3 are using large images equal to or greater than v3.00~14 any idea how to fix this
Hi @Markus_001,
Can you please try adding them with a different browser on a different device?
And report back the results including what browser and version you used.
Failing that, could you please revert one of the installations back to a normal release version and see if that makes any difference?
@Guy Stewart (Victron Community Manager)
I can add and remove the widgets on a windows 10 pc using Google Chrome. The problem is on an iPhone X iOS 16.2 funny thing is I can add and remove advanced widgets on some of the sites I’m linked to but not all.
I reverted two instalations back to the normal release, no difference still can’t add or remove advanced widgets on the same three sites.
31 People are following this question.
