I just bought a new EasySolar-II GX and connect it, I wonder why vrm portal dashboard doesnt find aggregate even it run and checked that voltage is in the GX device connector 230 - 240 V. Everything else pv charger, idle, AC loads seem to be ok.
38 People are following this question.
Adding grid tie to easy solar 5kva
Switch EasySolar with venus os on pi or with VEConfigure virtual panel (MK3-USB) doesn´t work
Victron EasySoalr measurement and minitoring system sensors positions on VE.bus
What type of current and voltage sensor does the EasySolar 48V;5000VA;70A use?
How many MPPT can I add on the DC side of the easy solar 48V/5000VA/70A?
