Anil Ghatikar avatar image
Anil Ghatikar asked
economic report Grid, Genrator , +ESS template not available
Does anybody have a third-party solution or workaround to calculate the savings when using a combination of GRID+Gernerator+ESS?
All the templates on VRM consider only GRID or Diesel as the only source to compare the combo .
Short of manually calculating the hours when the grid was not available I could not think of an easy workaround.
I basically want to see how much diesel was saved when the generator should have run ( grid failed) and instead ESS saved the day and ran the generator for a shorter period if needed
vrm advanced
